Configure CLI Logging
Use CLI logging to track all CLI commands executed and for fault management purposes. The CLI commands are logged to the system log file as CLILOG module.
The platform logs CLILOG and SNMPLOG as INFO. Normally, if you configure the logging level to WARNING, the system skips all INFO messages. However, if you enable CLILOG and SNMPLOG the system logs CLI Log and SNMP Log information regardless of the logging level you set. This is not the case for other INFO messages.
Switch:1>enable Switch:1#configure terminal Switch:1(config)#clilog enable
The following table defines parameters for the clilog commands.
Variable |
Value |
enable |
Activates CLI logging. |
